Return to Index
Read Responses
Which brings it full circle and back to bleach and filters. From another thread.
In Response To:
I'm saying that it IS ok...
Head Plumbing
Connecting sea water toilet to fresh water system is a no no....
Perfect! Thanks Peggie.
It only works IF the sink drains below waterline. If it doesn't here's a Plan B:
I switched over to fresh water flushing years ago...
Interesting... I know of Hunter boats that are cross connected by the factory
Gene, are you sure he didn't have electric toilets designed to use pressurized flush water?
The heads were electric... one button flush...
First of all, Gene...Lectra/Sans are not toilets...
So what you are saying is that it IS OK to connect these to fresh water supply?
Thanks Peggie...
Solenoid-activated engine fuel shut-off has a manual override lever. Not a problem if solenoid fails.
Not I could find... and I wasn't the only eyes looking...
Hmmm. Engine manual might help
Risky method....
Thanks, this wasn't your basic pillow.
Head Plumbing
Oh, that's easy!
Does the vinegar harm the joker valve if it sits in the discharge?
Yes...Soft rubber left to sit and soak in vinegar will swell and distort.
White Vinegar/Lectra San
White vinegar is actually good for it...
