Return to Index
Read Responses
White vinegar is actually good for it...
In Response To:
White Vinegar/Lectra San
'Cuz it can extend the time between cleaning with muriatic acid.
Get Rid of Boat Odors!
Head Plumbing
Connecting sea water toilet to fresh water system is a no no....
Perfect! Thanks Peggie.
It only works IF the sink drains below waterline. If it doesn't here's a Plan B:
I switched over to fresh water flushing years ago...
Interesting... I know of Hunter boats that are cross connected by the factory
Gene, are you sure he didn't have electric toilets designed to use pressurized flush water?
The heads were electric... one button flush...
First of all, Gene...Lectra/Sans are not toilets...
So what you are saying is that it IS OK to connect these to fresh water supply?
I'm saying that it IS ok...
Which brings it full circle and back to bleach and filters. From another thread.
Thanks Peggie...
Solenoid-activated engine fuel shut-off has a manual override lever. Not a problem if solenoid fails.
Not I could find... and I wasn't the only eyes looking...
Hmmm. Engine manual might help
Risky method....
Thanks, this wasn't your basic pillow.
Head Plumbing
Oh, that's easy!
Does the vinegar harm the joker valve if it sits in the discharge?
Yes...Soft rubber left to sit and soak in vinegar will swell and distort.
