rusted trailer rims
Hi Gene
There is a good likelyhood your rims are only stuck on the (centering)pilot Where the rim centers on the hub. If you heat the rim disc a little outside of where it meets the hub I think you will find it relatively easy to pry them off.(I used to clean and grease those two areas on my truck wheels to prevent problems.) Quickly heat the rim area ONLY. Good luck
