Return to Index
Read Responses
You could use Ospho on those hubs, stabilize the rust, Rustoleum them...?
In Response To:
Larger hammer worked...
Ideas on how to remove bearing spindle from Lewmar winch?
GOBI is watching you
Saturate in ....
Localized heating.
Thanks
Diesel
That's a thought.
PB Blaster before ANYTHING else
No worries.
PB Blaster
Taking apart an old boat trailer... Using PB... but I have a question.
Larger hammer theory...
I was actually thinking of One Step Rust Killer...
Sounds pretty good from here.
rusted trailer rims
Find a hydraulic press....
Also, the axle has to come out the top. not down through the gears....
Not on this model.
