The only way you can do any better than the Alpha is to go with a directional gain antenna.
You don't need height unless you're in a marina and being blocked by a neighboring boat. It's not as if you're trying to look over the horizon with these things.
It's not waterproof -- so keep it sheltered by your dodger or bimini. You can get a 15ft. USB cable.
