Sorry, I meant stainless!! of course it is stainless steel ! I got some new platinum bits that should do the trick. As for a 3/8 in hole in 1 in tubing...hmmm that's an interesting point! I guess the higher up the guard the hole is the less likely it is to cause problems, right??
