Return to Index
Read Responses
Gene: CALL Mack Boring (or some other Yanmar Distributor)
In Response To:
How do you know what impeller you need?
http://www.mackboring.com/Contact_Us.aspx
How easy is it to get to your raw water impeller?
Is it the 2GM20F? ( 2GM20, 3GM30, is the same story)
Yup, 2GM20F. BTW...
That is correct - 3000 rpm continuous would not be a problem, but
Thanks... I noticed that this engine does "sip..."
...they are one of the all-time great Yanmar engines (other than that backward water pump)
IT's not just the RPM -- it's the load on the engine trying to drive the hull at "over pressures"
Sure, no problem... but I think in my case, I have been way too conservative.
Yes, I think you are exactly right...
...another mitigating factor, obviously, is prop size and pitch...
Yeah, it's a pain in the a...
Kind of thing that makes you want to get it done on a maint schedule...
should have said... do it on a regular maint schedule.
impeller
Speed Seal
The new Yanmar impellers have a slightly different compound...
If you have the 2GM20F this is the number...
Surprised the model of the raw water pump isn't on the plate.
Globe Rubber----
Globe impellers
I did not have good luck with them...
I have not ever used one, but ...
