Return to Index
Read Responses
I did not have good luck with them...
In Response To:
Globe impellers
tried them in several engines and have had them fail after sitting idle a long time.
How easy is it to get to your raw water impeller?
Is it the 2GM20F? ( 2GM20, 3GM30, is the same story)
Yup, 2GM20F. BTW...
That is correct - 3000 rpm continuous would not be a problem, but
Thanks... I noticed that this engine does "sip..."
...they are one of the all-time great Yanmar engines (other than that backward water pump)
IT's not just the RPM -- it's the load on the engine trying to drive the hull at "over pressures"
Sure, no problem... but I think in my case, I have been way too conservative.
Yes, I think you are exactly right...
...another mitigating factor, obviously, is prop size and pitch...
Yeah, it's a pain in the a...
Kind of thing that makes you want to get it done on a maint schedule...
should have said... do it on a regular maint schedule.
impeller
Speed Seal
The new Yanmar impellers have a slightly different compound...
How do you know what impeller you need?
Gene: CALL Mack Boring (or some other Yanmar Distributor)
If you have the 2GM20F this is the number...
Surprised the model of the raw water pump isn't on the plate.
Globe Rubber----
Globe impellers
I have not ever used one, but ...
