Return to Index
Read Responses
Replaced HeadMate with PHC
In Response To:
A MUCH better idea than either of your plans.
I'm happy, the Admiral's happy - nothing more to say!
Head issues and assumptions
I would get the HF conversion kit
I love my PHC too
+3 My PHC works sooo much better than the Jabsco it replaced
Best of all, replace the head with a
My Lavac
Dave, you may be OVER tightening the bolts
I'm sure you're correct; so how much...
Our Lavac is bolted to a 3/4" thick Plywood base
I think using dry cork is your problem, 'cuz corkd doesn't behave the same way rubber does.
This is the first time...
I dunno..stand by while see if I have more luck getting info out of St. Brendan's Isle (US Lavac importer) than you did
Ok...just got off the phone with 'em...
