My Lavac
I have real difficulties with the Lavac Bases leaking. I contacted Lavac to see how tight the bolts should be for the head to the base and received no response. It is a plastic base with a plastic washer. I've cracked two so far. Not sure they're really setup for full time cruising. The idea is simple and mostly it works great. But the base's are expensive and the could have done a much better job on them.
