... Or she knows less than she thinks
If you're going to cook away from the dock with a 1500-watt cook-top your best solution is the generator. (Actually your best solution is to over-rule her and deep-six the electric -- put in propane. The generator is a band-aid approach.)
But the bright side is the generator has other uses for power tools, and to run your furnace or refrigerator when you lose power in a winter storm .
