Return to Index
Read Responses
I had a 175 watt 'West Marine that wouldn't run my computer
In Response To:
Similar question as Craig... but I am only thinking of enough power to charge small devices.
It would charge for about 15 seconds and then overload.
Tropical Dance Website
Power inverters
Craig you don't have enough amp-hours to handle AC power tool loads for long
Larry, I have one of those Chinese knock-offs
Heart 1,000 watt inverter/charger
I've found that the actual charging rate for the Heart Inverter/Charges is much lower than the maximum rating;
Agree, That's why I thought of the 1,500 as the better choice.
Interesting thoughts on the propane
... Or she knows less than she thinks
Propane vs Alcohol
Each burner on the 1500 watt cooktop is likely 750 watts...
Remember Dan, we cruise the sweet water sea
You will get use to the joys of an inverter
For power tools a simple one will do...
I plugged a Standard Horizon VHF charge brick into a modified sine inverter and the brick failed
For small wall wart devices, a sine wave converter is the way to go...
Thanks guys... good info there.
I"ve had portable computers, Icom chargers, Dewalt drills, TV/VCR's, etc. without any problems on modified sine wave
My advice is to think 12V first...
Thanks Jon... I did and have... but the market itself doesn't.
Small generator.. The new ones are very quiet.
