Return to Index
Read Responses
Take a look at 'aerogel'
In Response To:
Frig Box rebuild ... insulation material ...
http://inhabitat.com/exciting-advances-in-insulation-with-aerogel/
etc.
I think there's am estrogen replacement drug by that name,...
The "blueboard" is extruded polystyrene and is the economical choice...
Just Used Blueboard ...
I just read your lobster pot story.
It isn't as bad as he made it to be...
"and only snagged on(e) trap line"... yeah, me too...
Rope cutters work
Yeah, doing some of those things...
be real careful with that hooknife
Hook knife vs. Grab n Go hook
I have one of those too
I'd need to go into the water to use a hook knife
The way we were caught, the right hook knife would have solved the immediate problem....
I read you loud and clear on all that
The line I was snagged on was at least 1/2 or 5/8....
Wow -- I've never seen one bigger than 3/8
I've read your warp snag adventure DDW.
Good advice! Thanks....
Yep. Looks "catchy"
.... and one in the vertical plane extending down.
I'd strongly recomend configuring a line/connection between your keel and rudder...
Good Idea. Details ?
i may try that...
Another concern...
I know of a situation where a spectra line did some major damage
Jon - can you provide details of your hook knife & pole?
We made one that clips onto our boathook...
I used to have a sharp knife attached to a boathook
This is the one I bought...
I don't know about standard boathook
How's 'Anomali' handling the energy needs?
Update on the energy plan....
Wouldn't mind hearing
The Jefa autopilot drive...
If you plan on ever heading to the tropics
We have DC powered AC...
sounds very well thought out.
You can redirect your cool air?
No, but there are two evaporators....
We get water out of the AC vents all the time.
