and the color temperature "warm white" is close. The Sensibulbs are more than 8x the price, so it would be worthwhile to try the warm white SMD bulbs from eBay before committing to Sensibulbs. They sell them in every common pin type and base type. Rear pins, side pins, etc.
I don't doubt the Sensibulbs are better, but the eBay bulbs are brighter than the halogens they replaced. The only issue is they are harsh if you look straight at the unshielded LED, and I suspect this is the case with any LED. Makes me see spots, so I try not to look directly at them (so did the halogens, but not as bad).
