having a couple of Bebi Fautasi strip lights over the stove so I can see into the cupboards and not wake everybody up early. I added a second array since the picture was taken. And a Beka Kaukana anchor/cockpit light outside. Good article at Bebi about regulation of LEDs, but if they are cheap enough and don't cause much RFI you can just throw them away instead.
As mentioned above, just get spares if you want to avoid all the electronics that come with the Sensibulbs and Bebis. And avoid the "LED Cluster" type lights, at least in my experience. So far I have killed 3 Dr LEDs and 2 Lopolights, no Bebis or Sensibulbs. Oh and 2 OGMs, but that was water intrusion.
