Return to Index
Read Responses
Now there's an idea!
In Response To:
well, how about this?
Chainplate screwup.
what kind of bolts are you looking for?
So does McMaster-Carr
Isn't there a backing plate, Dan?
I seem to recall warnings about undersized clevis pins
The issue with the chainplate is not just the shear strenght of the bolts, Charlie
Bolt sizing
The induced friction from compressing the chain plate against RFP would help -- but ultimately, I'm not how much
You do NOT want to torque bolts too hard in FRP. You can crush the fiberglass structure and weaken the area.
structural joints
Neil -- the right stuff that stays flexible to keep water out without being brittle really wouldn't transfer stresses.
Further, Charlie
Split pin shouldn't take load?
Yes, I miswrote and my comment was about a spilt pin.
Dan, do you have the old bolts with you?
Update, photos and some info. after responses.
Just called Jamestown,,,, NADA!
How about looking for a metric equivalent? 9/16 =14.2875 mm. 14mm closer than half?
Found them at Mc. Master-Carr
McMaster
I was so excited they had them I forgot to ask.
I would think 316 is better,
I"ve never had a problem on boats with 18-8, however.
I didn't see John H's post below...
At the very least, put a light load on the chain plate...
Very light! ;^)
