At the very least, put a light load on the chain plate...
In Response To: Chainplate screwup. ()
with the backstay before tightening the bolts all the way. That way the chainplate is in it's final resting place when the bedding goes off and the bolts are all bearing on the plate on the bottom side of the hole. JMHO
