OK, Then your flush is just as long
In Response To: Hi Steve ... thanks ... ()
as you hold the button down then. I saw that schematic and took note of it in case my control module fails while out cruising. I planned on just re-wiring it up that way. It definitely sounds like they forgot something. It should be an easy fix. I looked into the way things are connected and it's all pretty simple back inside the thing. Good luck.
