Return to Index
Read Responses
The clamp-on's work better with higher voltages or loads than small 12v or 24v loads?
In Response To:
I did. I really liked that clamp on feature Steve talked about...
Need a new multimeter.
Never had a problem with that stuff.
If you don't mind spending a few bucks get
I bought a Fluke from an electrical wholesaler over 25 years ago.
$369!!! I don't want to buy the company, just a multimeter!
Can you say ....
I use a Fluke 376...
For us......
Radio Shack --
Stay with a cheapie...
That sounds good. I've bad luck with the real cheap ones.
Dave - for tracing wires nothing beats a cable tone generator / wire tracer
Brian, the fluke most likely floats. Did you
Steve...
I suppose you're right, anything can happen.
I agree with the consensus..buy a cheap meter...
I have a Velleman similar to this one
Cheap meter story
Had a similar situation... not on the boat... but yeah the cheap meter failed when I needed it.
I picked up my Simpson 260 at a local hamfest
Sometimes you can't beat an analog meter.
