Return to Index
Read Responses
Plus, you'll be "hauling" that weight around...I'd try and find some other solution other than adding weight.
In Response To:
At the risk of reiterating......
Trim ballast ideas and sources
Can't beat lead pigs, 50 lb'ers for size.
What about storm gear and engine parts?
Old tire weights.
Can I ask why?
Could you use more battery Capacity ? or move battery?
Port list (not fore and aft)
As usual, I can definitely agree with SG here.
I believe I would tend to lighten the heavy side rather than add ballast ...
