Return to Index
Read Responses
As usual, I can definitely agree with SG here.
In Response To:
Plus, you'll be "hauling" that weight around...I'd try and find some other solution other than adding weight.
Trim ballast ideas and sources
Can't beat lead pigs, 50 lb'ers for size.
What about storm gear and engine parts?
Old tire weights.
Can I ask why?
Could you use more battery Capacity ? or move battery?
Port list (not fore and aft)
At the risk of reiterating......
I believe I would tend to lighten the heavy side rather than add ballast ...
