There are a lot of different powder coatings
In Response To: Powdercoating aluminum? ()
The answer to your question is dependent on what type of coating you use. Have a look at the following links and maybe you can narrow it down a bit before you talk to your local paint shop. Look at the epoxy coatings if you don't mind the cost.
http://www.prismpowder.com/general_information
http://www.protechpowder.com/EN/am_home.html
