It seems like all the load should have been at right angles to these and it would have put the pressure on the hull side mount, not the left side lower mount. I wonder if the hull itself flexed and caused the problem. I believe it is mostly a carbon fiber hull. Or maybe the stainless bracket itself flexed
Paul L
