My shorepower AC panel has built-in GFCI. When I plug in any AC load the square green indicator light on the panel goes off and the breaker trips. If I reset the panel I can measure 120VAC using a multimeter. It only trips when there is a load.
Am I looking for a ground fault or something else? If ground fault, how does one test for and trace the issue?
