or, had it done, but I'll mention it just in case:
You need to have the freshwater(even saltwater) side of the engine cooling system winterized. It's not likely to drain on its own, and freezing can be catastrophic.
Also, if the drinking water system was re-commissioned during your tests, it needs attention as well.
Cheers.
