Return to Index
Read Responses
correction..the wind generator has a diode...
In Response To:
When you turn off the wind generator
it is a KISS and I just checked the owner's manual and there is a diode block
DQOTD~solar
It is operating correctly
the ammeter flucuates depending
it just stops turning...
Something not right
Think I solved the problem
Poor Form
OUCH! but right.
believe me it was the last resort...
John, You should be getting about
thanks Steve
Johnn -- look up the Flexcharge Solar & Wind Charge Controller NC25a
thanks Larry
You might want another controller on the wind gen
