Return to Index
Read Responses
What are her specs....on the off chance you have my old boat
In Response To:
She is a keeper...
Went out on a dead calm morning to test reverse...
Hey I used to own an Orion
She is a keeper...
See the line drawing in the post below...
Year says it all. Mine was an '85
Ah, you had the "extra" port and the longer area over the V berth.
Whatever direction you're going in reverse ...
Yeah, that's pretty much the case now.
Bigger rudder.
Sounds good to me Gene. You have better backing than I do.
I like Tom's point
Thanks, Tom does have a good point.
The trick will be anticipating drift from current and wind...other than that, it'll be a piece of cake
And I'm one! A retirement project.
Mine backs for s--t also.
You described the bottom to a T... and how the boat reacts.
Gene, that's a full keel.
OK, I understand, I simply took skeg to mean it was not hanging free
Dunno
I'll try it next haul out. Thanks
When I went from a skinny fin and Spade
