Return to Index
Read Responses
I'll try it next haul out. Thanks
In Response To:
Dunno
Went out on a dead calm morning to test reverse...
Hey I used to own an Orion
She is a keeper...
What are her specs....on the off chance you have my old boat
See the line drawing in the post below...
Year says it all. Mine was an '85
Ah, you had the "extra" port and the longer area over the V berth.
Whatever direction you're going in reverse ...
Yeah, that's pretty much the case now.
Bigger rudder.
Sounds good to me Gene. You have better backing than I do.
I like Tom's point
Thanks, Tom does have a good point.
The trick will be anticipating drift from current and wind...other than that, it'll be a piece of cake
And I'm one! A retirement project.
Mine backs for s--t also.
You described the bottom to a T... and how the boat reacts.
Gene, that's a full keel.
OK, I understand, I simply took skeg to mean it was not hanging free
Dunno
When I went from a skinny fin and Spade
