so you don't cut into your gelcoat. But the 3M wood grain and stripe remover converts the adhesive to some type of non-sticky compound that's easily wiped off with solvents. Much easier to use than heat and conventional solvents alone. It's worth the money, trust me.
Also, if you haven't seen them, search the web for plastic razor blades.
