Got the modified rudder frame back from the welding shop yesterday afternoon and began roughing out the foam. Today I'll finish fitting and adding some fiberglass reinforcing in the wide grooves cut for the 5/8" rod. I'll have a couple layers of mat in the flat portions between the rods when I glue the two sides together. Once I'm done shaping the entire thing will be wrapped in multiple layers of biaxial cloth and mat.
