How are you dealing with the bond with the metal?
In Response To: Thanks, Tom ()
I would think you should rough-up the metal (shiny isn' t good). You want to keep the components clearly attached and working together. I would guess that you have very different expansion and contraction coefficients (and differences in stiffness).
Is there something that will bind these together, Paul?
