The shape of the upper portion is staying nearly the same. I'm adding a little more area to the bottom trailing edge. BTW, the 5/8" rods that are perpendicular to the rudder shaft, where original bolts were, go completely through and are welded inside and out. A few friends and folks here cautioned me to make those load points extra strong.
