Return to Index
Read Responses
Of course I assume you are bending on the flat. If on the 2 1/2 dimension
In Response To:
Ronn- I just went out to the shop, picked up a piece of teak 1 1/4 x 3/8 x 40 inches
saw it.
A question for the woodworkers...
...I neglected to say it is Teak.
...and upon second and third measurment I should need only a one inch deflection.
...it will go here (this time there really is a photo)
...between the bulkhead and the hatch
That should go.
YOu might like to clamp it in place and predrill a mite if possible.
Long stick up from the sole perhaps, too.
long sticks a good idea too!
bandsaw
i'm going to put it up on the flat John
I see that now from your other resonses
Yes Charlie, on the flat - it will fill the gap between the hatch trim and the bulkhead...
not really- if you can hold the bend with something, like a piece of line
Wouldn't the 1/2" stock easily make the bend?
...dammed if I know, I was thinking maybe I should steam it and then
I ain't no woodworker either... but...
Mine are a litle less than 1/2"
Put it in a bar clamp for a few days
Agreed. It will bend easily if there is something to glue or screw to
You guys have given me some excellent tips...
