not really- if you can hold the bend with something, like a piece of line
slip it into place behind (inboard) the trim at each end, and release the tension it should stay bent- Think of a bow and arrow and a bow string. Looks like about a 1 x 1 on each side, next to the cabin sides.
Have to be cut to a precise length of course, but that could be found with a strip of junk ply or other cheap wood. Trim and fit, then cut the teak.
