Return to Index
Read Responses
Change the plugs. Cold runs, 7 year old plugs....
In Response To:
Any outboard gurus here?
Won't start means what? Turns over but nothing?
I will check but
My guess: bad gas.
Similar to Ken
I had a very similar problem with my Mercury 4 hp 4 stroke....
Check the easy stuff first
Yup. Always check the cheap..uh, easy stuff first.
Also, do you run out fuel after a day's use?
in order
