in order
In Response To: Any outboard gurus here? ()
Check to see you have spark. if you do, spray carb cleaner in to it and start it. if it runs for a second or two, and dies, the carburetor is plugged up.
Pretty easy to take these apart. If you are doing it on the boat, put the outboard in the dink and don't lose pieces overboard.
rich
