If you have any PVA ......
In Response To: As a last choice... ()
PVA - polyvinyl alcohol will affect a fast 'surface' cure to the tacky polyester. Its water soluble, and easy to spritz or simply brush on.
PVA is used as a final coat over freshly sprayed on gel coat as a 'surface hardner'.
