Return to Index
Read Responses
Thanks for all the advice. I found a heated garage I can put it in for several days
In Response To:
Only when you don't add wax
I took the advice of a few here to seal up my dinghy seams
I've had the same problem on several of occasions over the years. With mixed results, I've
Try a heat lamp......
When you say won't cure, to what extent are you referring?
Only time and ambient temp. will help you now.
Ack......so what about painting over a sticky surface?
How about tenting it outside and get some heat in there.
your catalyst (hardener) is probably stale
Larry has a good point
...we've all done this at one time or another
lol- Yeah, we have. I glassed 6 feet of deck once, with epoxy resin
As a last choice...
If you have any PVA ......
This just reminded me- there are two varieties of polyester resin
"Mop and Glo" great idea
My experience with layup resin is that while it doesn't cure "hard"
Hence my question about degree of "not cured". But no response from Mr. Currier, eh....
