Return to Index
Read Responses
Plus, is the valve open?
In Response To:
If it is a diesel line, have you put some diesel in the hose?
1/4" fuel line install
Something has to be wrong
Absolutely sure they are both 1/4"
Not sure if I follow you, what valve?
Well
I lube the hoses with diesel or light oil
Fuel line size
The only thing I can think of is that you were looking at the 1/4 in NPT
No winners, but this project is done.
A pot of "boiling" water dip the end for a few seconds..and then install.always works for me.
