1/4" seems pretty small - even my Atomic 4 uses 5/16" fuel line. Are the barbs brass or plastic? The plastic stuff seems to run larger - but I can't see you using plastic for fuel! I might run a poly line between the fuel pump and the carb, but I doubt you'd do that.
