Return to Index
Read Responses
Does a bucket count? Who on this board
In Response To:
ABYC requires 2 manuals offshore, I believe. One in the cockpit and one below.
has two manual pumps permanently mounted? Does anyone have one mounted below?
Whale Gusher 30
Whate Titan
Opps - Should be Whale not Whate
Might think about the Edson Pump
Wrong model, but I installed a bulkhead/deck Titan on my boat too.
Why would you want a manual bilge pump at all? I
Why - are you serious?
Yes I'm serious and no, I'm not really worried. With the
One in cockpit behind the wheel; and one to the port of the companionway steps in an aft cabin.
Um, I got a bucket anchored below, does that count?
One in thc cockpit and one under the cabin sole.
As I said before two thru the deck in the cockpit and I'm sure I'm not alone.
As I said before, sitting in the cockpit or
I think the two manual pumps are USYRU regs.
Whale Gusher 30
why would you want an electric pump at all?
To keep from sinking because a manual
what is the capacity of your electric pump?
