The aft ends of the stripes are finished, and the painting is done. What's left is to patch a few gelcoat dings on deck/cockpit from dropped winch handles etc. and apply the name again.
The center hull has a mid-level stripe fore and aft, and the floats have a bootstripe with angled break near the bows.
In this picture prior to painting you can see that the center hull sits lower when the boat is unfolded, so the different heights shouldn't look mis-matched visually.
