Return to Index
Read Responses
I wouldn't use Silcone under water -- it won't hold-up as long as other products
In Response To:
I had the same question and contacted Forespar...
Bedding marelon fittings
Marelon
If you have a cored hull, seal the edges of the hole with epoxy before you use the sealant for the thru hull.
Boat US and Practical Sailor have both reported on caulks. A lot depends on your caulk "number" but...
Below taken from Forespar site....
There's more info on that site, look for "how to, Marelon"
Couldn't stand it, here's the site link...
I see this site info is a bit different from what I quoted earlier...go figure.
I'm with you. 5200 below the water line.
Usually, the sealants that smell like vinegar
Let me clarify...
My boat came with silicone
LifeSeal from BoatLife.
Polysulfide and Polyurethane caulks are okay for most plastics.
