I had an electrical wire from my radar get into contact with the mast that set up a circuit. It was connected to the bonding system of the boat and destroyed every thru hull fitting on the boat. I would have sunk had it not been for the 5200 holding the valves to the hull on the inside. It's a long story but it made me a believer that 5200 is the choice for underwater.
