Chart plotters
In Response To: Educating the ignorant ()
Your two CPs have different charting packages. The newer one uses Navionics and the other uses C-map...vastly different. That would be a long discussion to compare. It does depend somewhat on where you are cruising. By the way, I'm sure they are not connected on the same network which gives you good redundancy.
