My impeller cover leaked a bit last year and over the winter and now the inside of the lower screw holes are a lovely shade of green. And the cover screws bind up before the cover gets on tight. What is the best way to clean our the corrosion from these holes? They are pretty small, so I'm not sure what would fit inside. Anything I can spray in that would dissolve the corrosion?
thanks!
Van
