The cover just has clearance holes for the screws and you can just drill them out until they clean up. The tapped holes for the screws are in the pump body. If they need cleaning up, you're going to need the right size tap to match the screws. Just take one of the screws to a good hardware store and ask for a bottoming tap. You won't need the tap drill as you're just chasing the threads.
