Return to Index
Read Responses
Can you turn the plate over and screw it down?
In Response To:
thanks Max, I should do this.
If it's not obviously warped
cleaning impeller cover screw holes?
You could re-tap the holes
Yup, use a 'bottom' tap ....
I wouldn't re-tap yet.
I meant to re-tap with the same size thread
I though you mean to enlarge the holes.
Sorry for the phantom 't' - s
more details and thanks
Could the screws be too long? Just a guess
don't think so, upper screws go in fine
If it's just the cover..
You might also want to smooth the mating surfaces
