"Bloxygen uses ultra pure Argon, a powerful and natural inert gas to drive the oxygen out of your container. Simply blow the oxygen out of your container with Bloxygen and then seal the lid. The heavy, inert Bloxygen gas sinks down to block oxygen from the liquid surface. Because Bloxygen is heavier than air, it will separate the liquid surface from any air that may remain in the container."
