Return to Index
Read Responses
Glass it up and then gelcoat the entire side of the aft end of the house...
In Response To:
how dumb is this idea?
IP should be able to provide the gelcoat. Gelcoat repairs of the sort I suggest are pretty easy.
Mount a nice piece of wood over it.
Wood with a timer on it.
Agree with Genec.... wood
Is there anything else you would like to mount there?
How about a fixed port?
Oh, 2" hole. Sorry.
Just call it a peep hole, then.
Pick up some plush toys, get some bean bags and turn it into a carnival attraction.
Two thoughts
Friend launched a 39' custom.
An inclinometer
If you're so inclined....
inclinometer.....hmmmm
check the Water Witch specs
2" hole is also standard for VDO gauges
Good idea, 'high water alarm'
